How to change color of cards in calendar view?
Kristian Nørhave
January 25, 2024
Hey
We are using the calendar in Trello Premium, but is there a way we change either the card colors or the calendar colors so it is not white-on-white in the calendar view? If we add a color to a card in board view, it is still white in the calendar view.
Thanks.
Best
Kristian
Nikola Perisic
Hello there @Kristian Nørhave  and welcome to the Atlassian community!
By default, sadly, Trello doesn't have an option to change the color.
However, the app named Planyway, can solve your issue by selecting the labels.
In order to accomplish this:
1. Download the Planyway app from the Power-Ups
2. Set few issues to your calendar in Trello, for example:
3. Open Planyway, and you should be on the Calendar view, like this:
NOTE: I am not affiliated with Planyway in any way, and you would need to accept the access of Planyway to your Trello boards - it is proven that it is a safe app due to the number of downloads.
4.Click on one of the cards from the Calendar:Screenshot 2024-01-26 at 10.22.10.png
5.Click on Labels, and you will get variety of colors to choose from
6.Result:Screenshot 2024-01-26 at 10.23.20.png
Trello does this as well, but the whole card is not being colored, only the portion of it.
Hope this helped you.
CJ Norris
December 17, 2024
Thanks for the info. I don't see a Planoly power-up option. Is it only available through Microsoft Teams?
Alexander Glowacki
April 29, 2025
The thing is: Planyway is a 3rd Party Tool from Kasachstan. So within the security guidelines of our company I am not allowed to use this for internal data.
So the best way would be an easy option to transfer the colors of the lists of the board to the calender or just have a color-option, where the calender entries are not dark colored on dark background or the same in white.
Register now
