How to debug live Power-Up in Trello desktop app?
Board Genius
My live Power-Up is not loading in the Trello desktop app (macOS). Is there a way to enabled some web/JS debugging or logging in the Trello desktop app?
Adam Cao
You can open the console via the Help menu or CMD+Option+I
Laura Holton _ACE Rotterdam_
July 26, 2023
Hi @Board Genius 👋
I'm so sorry to hear you're having problems with the macOS Trello desktop app, my recommendation would be to raise the issue with Trello support so they can look into bugs and the backend.
To contact Trello Support directly you need to raise a support ticket here >> https://trello.com/en-GB/contact
I hope this helps but if you have any other questions just ask away 😃
All the best,
Laura
