×Hi,
I want to include events in my editorial calender as an reminder that topics worth writing about might come up on that day.
How can I make sure that the entire time period of the event is displayed? If I use a normal card with the due-date function (start-end), the event is just displayed on the due-date.
Thanks for any help,
Sarah
Hi, Sarah. Welcome to Atlassian Community.
It might be the case to use advanced checks lists to create multiple due dates on the same card.
I've found a page that describes this procedure: https://support.atlassian.com/trello/docs/how-to-use-advanced-checklists-to-set-due-dates/
Let me know if it fits to your scenario
Thank you for the answer. This might work but as this is an advanced (paid) service, I can not use it (just test it).
So my solution is to copy the event card on each day the event takes place.
this is definitely a free solution. Thanks for sharing :D
