Can you please advise me how to permanently delete a card that has a power up repeat set up on it? I have tried to archive then delete. I have also tried to un set up the repeat power up, however cannot see how to do this. Thank you in advance!
Hey Sophie,
You might have to remove the card from repeating, looks like the Repeat Power Up is creating a new card based on the repeat. Even if the original card used to create the Repeat is archived, it will continue to create repeats.
You should find more instructions on how to stop repeats in this article - https://help.trello.com/article/1068-using-the-card-repeater-power-up
Sagar Rao | The Trello Team
