How to reset my Trello cards to uncheck tasks and move back to their original lists?
Nikhil Sable
October 10, 2020
I'm using Trello as a consistent weekly task manager, so each weekday includes the same cards and tasks. Monday has its allotted cards and tasks and is repeated exactly the following Monday. Currently it's very laborious to uncheck all the tasks and move the cards manually back to their original lists. There must be a way with a click to reset a particular day to its pre-completed form. I'd much appreciate advice on how to accomplish this!
Thank you,
Nik
Ludo
October 11, 2020
When you copy a card, the items of the new card are unchecked by default.
An another solution : copy a checklist from an existing card.
Stephen Addis
October 12, 2020
Keep a set of blank templates in a column called weekly templates, then duplicate and move over as needed.  Gets it down to about three clicks and done.
skridler January 10, 2023
The suggestions by Stephen Addis and Ludo are good work-arounds, but it would be great to have a button at the top of the checklist to uncheck or check all.
Like Maggie Field likes this
