As the question states I have a Custom Field, called Priority (it seem to be a feature available so I just used it) but now I have a little challenge in using it further.
The Custom Field appears on cards like this:
Now when I go to my Workspace and want to search multiple boards and filter by this 'Custom Field, Priority: High it does not work, why?
The annoying thing is that I did a search on one board and it works, I really don't understand this.
I am hoping and sure that there are a lot more knowledgable folk in our community than I that could resolve this so I'm really hoping to hear back from someone asap.
Many thanks in advance :-)
Kind regards
David.
PS: I found a very good link on the Trello Support page that details the special operators but I could not find a solution there.
https://support.atlassian.com/trello/docs/searching-for-cards-all-boards/
Hi Alina,
Thanks for the reply and you are welcome.
It is all in a good cause and rewarding to find solutions and if not then at least to have the courtesy of a reply so that I do not continue in vain, so thanks for that.
You are also right in what you say it is logical to think that you can use these custom fields more extensively but sadly not.
The solution I adopted in the end was the simplest.
I deleted all the custom fields and just use a plain but simple label as you can do more with this being a standard card feature.
But if one day that gets fixed properly it would be good to know.
Have a great day.
Kind regards
David.
Hi David,
There's quite an investigation you've conducted here! Bravo!
I'm sorry to say that your findings are correct. Although filtering cards by custom field is possible, searching is currently not.
We actually have it as an open feature request for the product team to consider! I'll add you as an official "+1" in support of this.
Thanks for raising your concerns. And have a great day!
Alina | The Trello team
I too would love to be able to filter by custom field - priority. Hoping that is in the works!
Hi Jen,
Thanks for resurfacing this thread! The prioritization of this feature request is still in the works.
I’ve added your vote as another “+1” to our existing suggestion, which you can access at https://jira.atlassian.com/browse/TRELLO-299.
I would also recommend you to visit that suggestion, log in with your Atlassian account, and click Start watching this issue on the right panel. This will help our product and engineering team understand more about which functionalities our users are interested in.
Also, when the ticket is updated by our product team, you'll be notified via email.
Alina | The Trello Team
Hi, Atlassian Team!
How do I include custom fields in my "global" board searches?
My question is similar. I have a lot of cards with different phone numbers added as Custom Fields. So when I search for a number across cards, titles, in the description, and in two different custom fields, I'm not getting a thorough search.
I've tested by searching for numbers I *know* to be listed in a custom fields and I get a "Nothing matching found" response.
How do I adjust my search parameters?
Hi Sarah,
The feature request linked above is still not resolved, so the global search for custom fields is still in the works, unfortunately.
We have a separate feature request to introduce a board-specific filtering for custom fields: https://jira.atlassian.com/browse/TRELLO-163
I've added another +1 in favor of this suggestion, but you can vote for it, too, to increase its priority for our development team.
In the meantime, I've tried creating custom fields with phone numbers of my board, and I noticed that when a custom field is set to the "Number" type, cards aren't searchable by phone numbers, but when the type is set to "Text", cards are being filtered by phone numbers as keywords.
I'll report this discrepancy to our development team, but maybe this could be a temporary workaround in your case. Have you possibly tried it already?
