I am trying to integrate plan.io with trello so that issue, bug e.t.c communication on planio get synchronized to trello dashboard.
On internet I am only getting link for redmine to integrate to trello.
Also I found https://zapier.com which only allow to integrate redemine to trello. It doesn't have planio app in their database(searching plainio in search bar after login found no result) to link.
Any lead highly appreciated.
Thank you.
Hi Abhay,
Currently, there isn't an integration available between Trello and Planio. However, if Planio has an API available, you may be able to use the API to create your own integration.
Trello's API is fully documented at https://developers.trello.com/.
