×My customers do not want to see everything in our boards, its overwhelming. They want to check the status of a card (with a ticket number) and view it in a pizza tracker or similar way instantly. Is there a powerup for this?
Hey @Andrea Hudson you might be able to set this up with Unito or another mirroring/syncing Power-Up, but they are usually paid apps.
You would have your main board you work from, and then select what info to sync/mirror across to another separate customer facing board.
https://trello.com/power-ups/595e989fa8f137d2af456fd4/board-sync-by-unito
Hope that helps,
Dan
