Is Trello HIPAA compliant?
John O'Connor April 12, 2017
I'm looking into starting a coaching business and I need a application like Trello for client management and accountability. But most important the software has to be HIPAA compliant.
Daniel Eads {unmonitored account}
April 12, 2017
Hi Josh,
It doesn't look like Trello is currently HIPAA compliant, but it does adhere to the US-Swiss Safe Harbor Framework. You can read more about Trello's privacy policy and compliances here: https://trello.com/privacy
My concern is the liability issue, if personal information which is sensitive, is accessible to Trello administrators or hackers.
April 12, 2017
I definitely understand that - privacy is important! The privacy policy linked above is written in a non-legalise manner that I'm finding easy to understand. It's definitely not lawyer jargon. I'd suggest giving it a read to help address your particular concerns. The policy will do a more thorough job of explaining things than any of us on the Community site will be able to do.
Thanks Daniel...John
Kirti Moholkar April 22, 2019
I know that TRELLO was not HIPAA compliant in 2017 as per the attached thread. Have matters changed since?
Glen Miller
August 13, 2019 edited
I am an advisor for healthcare facilities. The question here is not an uncommon one.
Trello (and also certain software like Trello) should be avoided, as it represents tremendous legal risk. I cannot underscore that enough.
This is due not only to the risk of user error. You could think of Trello as a data company similar to Facebook. It categorically conflicts with the guiding principles of healthcare organizations and health data. Your process for evaluating and selecting a project management software must be equally rigorous to your process of selecting an EHR system.
If you are a smaller healthcare org or simply too resource-constrained to spend time researching appropriate project/task management software, my suggestion would be to contact your EHR provider. While it's probably not their job to find project/task management software for you, they will probably be nice enough to provide you with suggestions or pointers. They are already intimately familiar with your data-privacy needs and computer systems.
Ziv Kraus
October 31, 2019
Hi Glen, thank you for your crystal clear warning.
I work for a healthcare that is smaller/resource-constrained, as you said. I was considering pitching Trello for our leadership team, and am trying to figure out a solution that is both HIPAA compliant and cost efficient (ideally free).
Here's my question: is it acceptable to use a non-compliant solution like Trello, if we strictly refrain from using patient identifying information? For the most part, I don't anticipate needing to refer to patients in Trello. Would it be acceptable to use a patient's Medical Records Number, if it is assigned and used only internally within our organization?
Thank you for your help.
Like • Heather Shannon likes this
Heather Shannon
May 17, 2021
Curious if this was ever answered as I have the same question.
Like • Dele Olaleye likes this
Dele Olaleye
July 19, 2021
Yeah, has things changed?
Brad Larsen July 24, 2024
Has anything changed here?
