×Hello,
I would like to be able to display a large number of Lists across the screen at once without having to use the horizontal scroll bar. Is there a way to adjust dimensions as with Excel cells? The data entries consist of relatively few characters.
Right now, the width is fixed. If your lists are not very long and you would like to keep them all visible, you may want to consider using a grid view which can be accomplished with a 3rd party extension: https://chrome.google.com/webstore/detail/list-layouts-for-trello/aldklnbenbdgfgfbflalmlddkkndgnlc
Thanks for the quick and detailed reply- I am testing out the extension.
Rgds,
Chaz
