I have a process with various lists and I would like to know how long each card stay in each List. If possible, extract later in an excel the card tracking informing the time spent in each list.
basicaly is a Lean information
The Power-Up you are looking for is probably Time in List which does all of that.
Blue Cat Reports also has a Time to Complete chart which can track times between individual lists or across multiple lists. It also allows export as CSV. There are a lot of other charting options in Blue Cat as well, so may be better value if you want any of the other reporting options there.
Hope that helps,
Robin
Hello Robin,
Thank you so Much, i'm going to try it.
You can also try assista
Hi there!
Card Time In List for Trello can do all the following for you:
- It automatically calculates the dirations the card has spent on each list
- It can display the amount of to until due date or past due date
- It has a cumulative duration mode, which sums up the dirations on specified lists
- It can export duration reports
- and much more…
Cheers!
