Is there a way to move cards from one column to another at the end of the day?
Maybe using Butler's power-up? I wasn't able to find a way to create a rule that moves cards after a specific time, for example:
At the end of the day (6~7pm on my local time) I would like to move a specific card from one column to another.
Regards
Henrique Bittencourt
Yes you can use Butler. Go to Calendar on the left and choose create a scheduled command:
There you can create a rule that looks similar to this.
In the example I have two lists one called "Todo Tomorrow" and another one "Todo Today".
Hope this helps,
Reto
