×Hi I'm using the free account on Trello and I'm having issues setting up the GitLab's power-up on it.
I don't have any other power-ups activated (not exceeding the free limit)
Steps I took so far:
The token I've created has no expiration date and I've checked all of the scopes.
I've tried making a few other tokens, but all were regarded as invalid.
What am I doing wrong here, I'm really surprised by this issue.
I'm having this same issue. Was there ever a resolution?
Yes. The problem is small and can be simply solved.
The Trello's default gitlab API endpoint has a trailing slash ( / ) at the end, that messes with the URL's.
Try using the default GitLab API endpoint and just remove the slash from the end.
Yup, that was it. Thanks!
Hi Mihailo,
It's me again. I see you've already submitted a request and that Mike got back to you. I'll keep our communication on email.
Hi Mihailo,
Marta here from Trello Support.
Sorry to hear you're having trouble with this. So we can further troubleshoot this with you, would you mind submitting a request to us here trello.com/contact
If you could send us a screenshot of what you're seeing along with the descriptions of the steps you've followed (as given here), we'll be happy to investigate where the problem might be.
Many thanks!
Marta
