Hello
I use this Butler command :
"for each card linked from an item in checklist"
after I have created linked card from an item.
I want to copy the cover automatically from the trigger card to linked cards.
Does someone tell me how I can do this with Butler ?
Thanks.
Hi Ludo,
This might be pretty tough, as Butler's support for attachments is a little limited. You can use the variable {attachmentlink}, which represents the link to the attachment file itself, but this is only available in rules like "when an attachment is added to a card". You can't directly copy attachments between cards, but if you base the rule off of when an attachment is added to the card, you might be able to reference the link in order to attach it again on the linked cards!
Hi mikelj,
Thanks for your answer.
I use this command :
convert all the items in checklist "Ok prod" into linked cards in list "Liste technique" copying labels
There is a restrictiv option
copying labels & members
Missing attachment copying option for my use.
I have a trello Gold account. I think I don't have permission to access to butler action allowing copy attachment link
