Kalender Power-Up sync delay
Marcus Andersson September 21, 2023
We use the Kalender Power-Up from Trello and it takes a long time to get the information synced to the calender view when we create an card.
Anybody that has the problem?  Any suggestion?
Oliver S
September 24, 2023
Hi Marcus, welcome to the community!
Do you mean it takes a while for the card to show up on the Calendar view itself in Trello, or to a third-party Calendar - e.g. if you've enabled sync to Google Calendar (for example)?
Main thing to make sure it appears on the Calendar view itself is to make sure a due date is defined on the card: https://support.atlassian.com/trello/docs/adding-dates-to-cards/
Marcus Andersson September 30, 2023
It is the "trello Kalender" not a 3rd party calender that is the problem.
I have 4 boards and I have a calender where I can se the cards from all 4 boards.  When adding a card on one board it takes a while until I can see the card on the calender with all 4 boards.
Oliver S
October 1, 2023
Hi Marcus, thanks for clarifying. Sounds like you're making use of the Workspace Calendar View and experiencing a delay before the cards come up.
Taking a look, I can see there is an existing bug internally for this issue. I've gone ahead and linked your thread to the bug to pass on your feedback! While I don't have an ETA, it's there for review and consideration by our product team.
Understand the inconvenience and frustration this causes, so we appreciate your patience as you make use of this feature.
