I use two different Trello boards (on the same account). Is there a keyboard shortcut that would let me switch from one to the other?
Hi Pat,
I don't think this is exactly what you're asking for, but have you tried the `B` shortcut key? Because starred boards appear first in the results, I can usually get to my most important boards with 2-3 keypresses. (B + begin typing the board name + enter will take you to the first result).
Additionally, the desktop app has shortcuts for accessing your starred boards. This page has additional details (scroll down to "The menu bar" section). https://support.atlassian.com/trello/docs/trello-desktop-apps/
Hope this helps!
Thanks, Andrea. The "Find boards by name" dialog box isn't quite what I'm looking for.
