That’s great to hear that your issue has been resolved.
Hi @MikeNick , the Trello team indicated that disabling the “card Colors for Trello” chrome extension, and if you don’t here that enabled check for “pm for Trello”? Two users now no longer have issues with labels after disabling those extensions. Let me know if that helps.
thanks,
jodi
Worked for me! Went to my chrome extensions and removed. Refreshed and done! Labels are there.
I am having same issue and checked my google chrome. I don't see any trello extensions and I've tried the semicolon trick. Still cannot get my labels to show on card. Any other ideas? I also cleared my cache
Oops!
Quick hotkey search solved the mystery. Semicolon toggles label names. Didn’t expect that to toggle colours as well.
Done.
Hi Mike, I'm facing the same issue with labels while using Chrome.
is your semicolon tip work with Chrome too?
That worked for me too! Thanks for the tip!
Thanks! I knew I toggled the names, but I had no idea on how to show them again
Is there a way to force labels always to be displayed (for all board viewers)? It seems they regularly disappear from my boards and while semi colon brings them back, I worry that other viewers of the board suffer the same issue and do not know the shortcut to bring them back.
In our case, this significantly reduces the ease of use of the board if the labels disappear, so i would like to disable the "hide labels" feature altogether.
Thank You for the answer, This helped me!!
Thanks for this - would never have worked it out without this post!! :)
Hi @Jodi LeBlanc ,
My labels are still not back and I have already cleared the cache on my chrome... What should I do?
use this combination: "bloq fn" + " ; "
I'm on a Mac. This is the 2nd time I've lost the labels but I can't get the ; trick quite right... Help
same here.... labels still not showing after disable extensions.
cleared my cache and now labels are back! Suggestion from Jodi works :)
So glad it helped @Chen Si :)
