Hello, would also need this Trello card merge function.
Adding my comment to make the request go higher in the list ;-)
Conversations here are not looked at for any weighting, you'll need to go to the development/request/support boards for it.
Trello or JIRA?
The response I received is that isn't possible. You just have to physically move the data to the cards.
Hi Anne,
Thanks for your feedback...❤ Appreciate you taking the time to respond!
I suspected that might be the case 🙄... Unfortunately!
Maybe someone in Support will see this and add this fuction?!?!
