Has something changed with printing cards recently? We used to print cards from our boards just fine but within the last week or so it has changed so that the print dialog only shows 1 page, even if the text on the card was significantly longer.
This seems to be the case irrespective of which browser we use. I get the same behaviour in Chrome, Edge and IE
Is there a way we can force it to print the whole card?
Hi Colin,
To close the loop on this, yes, we made a separate and unrelated change the other day that did inadvertently break printing like that. Sorry! 😳
We've already rolled out a fix, so printing should be all back to normal now!
Still cannot print. Print preview is a blank sheet?
Same things happening with me. I am a paying user and I need to be able to print cards, which I have historically been able to print via Trello. I am only able to print a blank page now. Is there a fix to this problem or not?
I only have a blank page as well... help!!
I've noticed the same problem, whatever the card I want to print there is one blank page, when it will be available again? Still using the shortcut CTRL+P it happens to me as a problem.
Same here - blank page only.
@Alex Freitas CTRL+P doesn't work for me either. Currently using the Agile Cards power-up as an alternative.
Great tip @Kyle Chin , I have already installed this power up , thanks !
Hello
did the same, but would rather like to get it fixed via trello since i am using trello from several different device ..
That is GREAT NEWS!!
Does it happen on Firefox too?
Maybe you could try to unable some extensions if you have them (like AdBlock, for example).
Hey @Colin Ward,
Adrian from Spartez here - creators of the Agile Cards for Trello power-up.
It offers greater flexibility when printing your Trello board, lists and/or cards, plus it's free.
We have three predefined printing templates for compact, board and full-page cards.
You can find out more info here - https://info.trello.com/power-ups/agile-cards
Feedback is always welcomed on our public Trello board too.
Hi Adrian
We have actually resolved our issue by using your Power-up. Selecting the 'multiple pages' option for full page cards allows us to print the full description for cards where it runs over 1 page so thank you for that :)
We never used to need to use a power-up however, so I still wonder if something changed
Colin
I had the problem too and it's now solved. But today Agile Cards does not work any more. Even if the power-up is selected on the board, the fields that allow you to print do not appear (on the board and on the card).
Thanks for your help
Fred
Hi @Cavalin frederic,
Thanks for the notice!
Do you have any other power-ups enabled that may conflict with Agile Cards?
I've created a card on our public Trello board, it would be great if you could give more details there - https://trello.com/c/OwpucliJ
The problem is solved.
I tried to reach the card but it's impossible de write on it. Must be a member of the board I guess.
Fred
