Sign up Log in
Removing invited users
Don VanDemark
August 23, 2018
I have invited some potential users to Trello in the past but they no longer are needed on my boards. They have not accepted the invites. How do I remove them from the Invited list? It's getting jumbled in there.
jeffreylees August 26, 2018
In the web view, at the top of the board, you see a list of members. If you select the invited member and then just hit remove, you can remove them from the board.
Trello treats invited members as members of the board who simply have not set up their account yet, so it works the same way as removing any other member.
Don VanDemark
August 26, 2018
No idea how I missed that. Thanks.
No problem!
Anton Perera August 24, 2018
If it is a board which uses a Team, how about changing the team ?
I think you may have to create a team first with the potential users in nowadays for the board. Then change the team to that one.
