Repeating or copying cards weekly for planning
Lukasz
July 5, 2021
I'd like to use Trello to make a schedule to allocate colleagues sitting in our office on a rotating basis - something like a coworking space management.
I have set up lists corresponding to rooms, and have 2 labels - "regular weekly schedule" and "one-off occupancy".
I have populated the board with this week's schedule, and am visualising it in the timeline view:
Now, I'd like an easy way so that cards can be copied into the next week - and then the next, and so on. Bonus points if it can be easily and quickly done for the "regular schedule" label only.
This needs to be done a few weeks in advance, and my tries with the card repeater powerup make me understand that it only creates a new card right at the moment when its time comes - but I want to have a view a couple of weeks ahead.
Thank you for all the help!
Lukasz
July 7, 2021
So I found a way to copy a card into the same list, and so the solution I went with is quite a bit less complicated than the above. I created a button with the command:
copy the card to the top of list "{triggercardlistname}", move the due date to the same day next week, and move the start date to the same day next week
This makes a copy of the booking for the next week. Still requires some manual clicking, but for now it should do.
milynnus
July 7, 2021
@Lukasz
Glad that this will work for you. Mine is an ‘extension of sorts’ to the Card Repeater Power Up to be able to see a number of weeks ahead. 🤛💪
milynnus
July 5, 2021
@Lukasz
Are you any closer to a solution? This requirement has been asked before but I have not seen a recommended solution. The requirement as I understand it is to layout repeated cards ahead of time so that they can be observed in a calendar  view and to perpetuate and add each new cards as time passes. Am I correct?
milynnus
July 5, 2021
Lukasz
July 6, 2021
Hi Milynnus, thanks for your help!
So what I'm doing for now is I've created a card button with command
The simplest way for us to use it is that I click a card I want to copy over into the next week, on the back of the card I click "copy" and make sure it is copied in the same list, and then click my custom button. I end up with the copy remaining in place for the current week, and the original moved to the next week.
It would be great if I could have the copy action under the same button, but I cannot see a way to copy a card within the same list - the butler only allows me to copy a card into a specific list, but not into the same list.
Lukasz
July 6, 2021
Oh, and yes - your understanding of the problem is 100% correct.
milynnus
July 6, 2021
@Lukasz
So the solution I have involves gathering all the weekly booking cards in a checklist you need to extend out for x weeks ahead.
Update that card's checklist the last set of {cardidlong}.
Use this card to extend the booking a week at a time until you stop it by moving it out of the "Run" list.
Added some logic if the booking is for Biweekly bookings.
So far so good.
Update : a weekly program runs to extend the list. Uses the same code.
milynnus
July 6, 2021
Wrong Post ...sorry
