I want a rule that will comment on a card if a card has been in a list for too long (e.g. 7 Days).
How can i do that?
best regards
In the calendar automation you can "move all the cards more than x days in list" to another list. You can use that as a way to trigger the action you need and return the cards to their previous list.
Hmm did not work:
1 hours after a card in list "example" is due, post comment "test"
It is an action under List in Calendar So you pick a trigger like every day at 8pm. , then move the cards out to a trigger list. Have a rule to watch for cards moving into that list, add a comment action and move the card back to its previous list.
