×This is one of the most annoying features Trello has ever pushed out. There needs to be an option to turn this off.
Super annoying, super un-professsional, bugs bringer, dangerous when linking competitors, super anti-programmers, better migrate away if they don't fix it.
After months of usage, we came to the solution that every link we put is entered as a `code` so we put `https://www.google.com` for every url to avoid Trello auto-resolving it and/or notify competitors that someone is using them in a trello project :p
Hope this helps.
I've become innured to constantly deleting the protocol part of each link after I paste it, turning https://www.site.com into www.site.com. This restores the sane behaviour Trello used to have.
However clients aren't doing this, and the new behaviour is a constant pain point.
We have a particular type of email that contains a one-time link. The client pastes an example of this email into a Trello card and ... poof! ... the link is visited (by Trello) invalidating the test case. Is there any point even trying to explain to clients what's going on here? I think not.
I did it - what you have to do is use markdown.
So put your link both in [ ] brackets and then ( ) brackets.
So e.g.
[https://extinctionrebellion.uk/](https://extinctionrebellion.uk/)
Obviously that a bit annoying - but it helps when i'm leaving notes for other people and want them to see the url
Absolutely astounding that there is not a toggle for enabling or disabling this behavior.
So the best solution I've generated is to simply drop or space the preceding "h" in your link:
h ttps://www.getgvl.com/cart/39436718309443:1,39436713099331:1,39323828060227:1,39323863744579:1,39436754944067:1,39575919034435:1,39436716671043:1,39323817967683:1,40027014889539:1?discount=FOUNDATIONS
Why is this feature still forced for users accross all/many atlassian products ?
It absolutely makes ONLY harm in every place where it is!
Don't get me wrong, there are still several reasons why this is bad, as can be seen by some of the comments.
However, most other comments try to point out problems that aren't problems at all but rather user errors. When you put a URL in a card when the words themselves in the URL are important rather than visiting the link, then at that point the URL should not be a "link" at all, but should be written like code, in back-quotes. If you put URLs in back-quotes, they don't get resolved and reformatted as links anymore. (This works both in the description and in comments).
I agree that this "could" be seen as a shade of user error. However, and this may be different for some, but most of the members on my boards are non-technical folks who don't naturally know to put code and important URLs in back-quotes or codeblocks. Using back-quotes is second nature for developers, but non-technical folks usually don't even know they exist and often forget to use them when asked to do so.
Additionally, using back-quotes for adding URLs is great, but it makes them unclickable. When I paste a URL into a comment I almost always want it to be a link, e.g., be able to both see the URL and be able to click it (without needing to reach for markdown). This is how Trello has worked from its inception, and it's hard having it removed for what many here see as little gain.
Just my 2 cents.
I respectfully disagree. Calling URLs 'code' is a reach. The code formatting block is to preserve whitespace. Anything else is a side effect.
If I'm posting a URL, it's because I want to post a URL, not a hyperlink with a page title.
Ed has posted many examples in this thread illustrating exactly that pain point.
We live in an age where companies just do not care. Updates and breaking changes are pushed out without consideration. No communication. Six months without a solution - a very simple solution - being provided. It is mind-boggling.
The only answer is to switch platforms.
@Matt Summers I agree with you more ;-) I've been dogged by this so-called feature for six months and it's driving me nuts. I've posted on this thread three times and opened a support ticket that went nowhere, Atlassian is not listening (or don't care). The thought of moving numerous clients to a new platform is painful, but I'm considering it.
Solutions:
1.
Write links without http(s)://
for example:
trello.com/b/nC8QJJoZ/trello-development-roadmap
but not:
https://trello.com/b/nC8QJJoZ/trello-development-roadmap
2. Add CSS in browser. It's easy.
Use Extension like "stylebot"
add the rule for trello.com :
.atlaskit-smart-link:after {
Hope it helps!
Removing the https or adding backtics doesn't work when I need to copy and paste the URLS a corworker posted. Please get rid of this "feature" or at least add a setting to turn it off. Thanks.
there is only one simple way is, Using Trello in mobile
in the android mobile trello app the links won't change into hyperlink
if we copy the link in the android app, it will be copied as a direct link
we can paste it anywhere..
I'll copy the links from Trello mobile app, and send to my team from skype or WhatsApp
this is little less annoying but this is the only way for now
This is still a problem !
I have put in my user profile to keep urls and not previews, yet the old board's card description field's pasted url get converted to card
WHY?!!?!
Trello - Atlassian - Please fix this urgent issue.
The request has been made a abundence of times over a very long period and this should be a quick fix.
I had a work around, click on the edit button, then copy the text, but for some crazy reason, you turned this off too. This makes Trello not much use for many people.
It's an easy fix - just do it!
