## Switching between starred boards with short cuts does not work anymore since introduced sidebar
Patrick
September 9, 2021
Hi lovely community,
I loved the short cut function Ctrl+1, Ctrl+2, etc. to switch between my favorite boards, which I marked with a star. The major advantage is that I can switch instantly between my personal boards and my workspace boards. However, since the sidebar emerged, I am only able to use Ctrl+1, Ctrl+2, etc. to switch between the board WITHIN my personal boards or WITHIN my workspace board but not ACROSS the them.
In windows, the short cut function to my favorite boards, as I know, is still listed under the menu button (see image below) but even here they do not work anymore. How do I make them work again?
Lara
September 16, 2021
Hi Patrick,
Thanks for reaching out!
Our team is aware of this and are working on a fix šŸ‘
While I don't have an ETA on when a fix for the issue will be pushed, as soon as one is available, we will deploy it.
Please let us know if you have any other questions, and we'll be happy to help.
All the best,
Lara
The Trello Team
Lukas October 6, 2021
It seems that the shortcuts are only working within the workspace, you're actually in. If you're in another workspace, for example one where you are a guest, then only the shortcuts for boards within this workspace are workin. With other words: Shortcuts don't work, if it's necessary to change the workspace to reach the concerning board. Hope, my infos help.
