×Hi,
I wrote a company own PowerUp, tested it until yesterday. Everything worked fine. But today the PowerUp won't load anymore and I have no idea why I didn't change something.
Any ideas?
Thanks in advance.
Dennis
Edit on 2/12/2018: We've just launched a new Power-Up admin portal that should resolve the problems that were occurring. You can see the new admin portal at https://trello.com/power-ups/admin! You can read about what changes were made at https://developers.trello.com/v1.0/docs/migrating-manifests. And documentation for the new Power-Up can be found at https://developers.trello.com/docs/managing-power-ups.
Hey Dennis,
We've recently made changes to the way we handle Custom Power-Ups that are likely the cause of the problem you're experiencing. The bad news is that it takes about five minutes for the custom Power-Up you registered to be available on your Trello board. The good news is that the Power-Ups menu is much faster!
Here is what is happening behind the scenes: previously the Trello web client would make a request to every registered Power-Up's manifest file, leaving the web client waiting on those other servers' responses. We've offloaded this responsibility to the Trello server so that when you register a Power-Up there is a task that queries your manifest every five minutes and stores the data on Trello's backend. Now, when the Trello client goes to load the Power-Up menu it only needs to query our server.
This is only a short-term solution as we are working on adding fields to the Custom Power-Up admin page that will allow you to give us the manifest's data directly.
How To Proceed
After registering a Power-Up, wait five minutes. If the Power-Up doesn't load as expected, then it is likely that our task failed to grab the data from the manifest and update our server. This can happen for a few reasons:
Still stuck? Don't hesitate to reach out to integrations@trello.com. We're happy to help you out!
Finally, sorry for the inconvenience. We're hopeful that a more delightful Power-Up menu experience will lead to more users enabling your awesome Power-Ups! Once we launch the new Power-Ups admin, none of these issues should persist, and the power will be in your hands.
