Update: I have it now displaying the photo as an attachment, as it did under BlueCat Forms but the other photos are gibberish. I have attached a screenshot.
I used to use BlueCat Forms but it was too dang expensive for our tiny nonprofit. So we switched to Typeform. Volunteers fill out a form with a bunch of info along with a few pictures of their foster cat. Typeform then throws that info into a Trello card for another volunteer to use to create an online bio for the cat But Trello is creating a field for each photo uploaded to the Typeform form like this: https://api.typeform.com/responses/files/d65e7ddf1542e52445f3b2eaedfe9489a4eb81328493a77bdcad1be47203f521/IMG_2794.jpeg
This is super annoying as you can't just right-click and download. You have to copy and paste it into a new window, then download it. Also, the volunteer might submit several pics but maybe only one or two are acceptable. What a waste of time to have to copy/paste each file name/location into a new window just to see the pic.
How can we have the actual photo load into Trello? Typeform does store it as an attachment, so might that be a limitation of TypeForm?
Also, we like to have the first attachment/picture as the card's cover for quick identification purposes.
Hey @KerryAnn May! I recommend sending this over to Typeform support, they built the Typeform Power-Up and should be able to help here. You can reach out to them at support@typeform.com
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
