Using Custom Fields & Calendar Power Ups
Leigh Anne Buttrick
January 10, 2018
Hello!
I'm currently researching Trello to see if it's a good fit for a business need.  I'm currently using the free version, so I'm only able to use one power-up.
My question is - if create custom fields with additional dates - will those dates populate in the calendar?  I'm looking to visualize the duration of cards that last longer than one day.
Any advice or other work around are very much appreciated!
Thanks in advance.
Leigh Anne
Matthew N
January 10, 2018
Leigh Ann
Custom Fields, even as a date, won't integrate with your Trello Calendar.
For this, I would recommend checking out the Planyway Power Up/Calendar.
