Sign up Log in
WHICH TABLES ARE UPDATED IN DATA BASE WHILE ISSUES MOVING FROM ONE TRANSITION TO OTHER IN JIRA UI
Santhosh Vegolam March 1, 2019
Hello Team,
any body please can help on this
i want small help regarding db tables on below
I want the DB tables details while we are transition of issue which tables we can see updates. like moving from To-do to In progress and then In progress to done etc
We are using postgres(Type-postgres72) database with version-9.5.10
our jira version is 7.9.2
Kindly request you to share the db tables names
Nic Brough -Adaptavist-
March 2, 2019
It depends heavily on what data the issue has on it and what is configured for the issues.
I would strongly recommend NOT looking at the database for this.  It's complex, messy and hard to read.
Could you tell us why you are asking?  What are you trying to achieve here?  If we know that, we can almost certainly give you a much better (easier, faster and less complex) way to do it than listing 2/3rds of the Jira database and explaining the fifty or so tables you might have to read.
Santhosh Vegolam March 2, 2019
Hello @Nic Brough -Adaptavist-
This data is requested by other team in our project so we have to provide this data
Like whenever we are moving transitions like from TODO to INPROGRESS and then INPROGRESS  to DONE etc   in jira UI
In database while doing this transitions/status change which tables are updated this changes or in database these entries(transition changes) are effects which tables are stored this updates
so kindly request you to provide this db tables or provide any relevant to this
santhosh
Tom Lister
March 2, 2019
Hi @Santhosh Vegolam
Have you at web hook functionality and REST API to communicate with other apps?
Hello @Tom Lister
Thanks for quick response
we have webhook with slack application also RESTAPI
Tom Lister
March 2, 2019
Good
that will get you a more reliable way to watch events than any database polling
more info here
https://developer.atlassian.com/server/jira/platform/webhooks/
Hello @Tom Lister
i am not looking for this link/information exactly  i want db tables while transitions/status change in jira like whcih tables stored or updated in database while performing workflow status change in jira UI
if any please provide
i hope any database feels same and not sure but we are using postgreSQL 9.5.10
Tom Lister
March 2, 2019
I'll give you a quick starter for 10, but I won't have time to go down into any details on this forum
If you know your issue id look in the jiraissue table which will show you the current status
the status name will have to beg looked up in the jira status table.
with an issue id you can find a record of changes on the change group table
the change group is linked to change items which records the exact changes done. This is one of more byzantine bits of jira data. To find a transition , you need to look for the last change group that contains an item that changed the issue status
if you want to then retrieve details of custom fields attached to the item you will have to unpick customfield, customfieldoptions, customfiledvalues
Comments are buried in the jiraaction tables
I can feel PTSD coming on just thinking of going back in there.
REST API - you'll thank me for that advice one day
Hello @Tom Lister
Thanks for your valuable time on this
I got your provided information  will more helpful to me
Thank u so much and i will appreciate your help
i will let you know if any more on this
Thanks once again @Tom Lister
santhosh
March 2, 2019
Tom has given you some of the tables that could be affected by a transition.  There are another 30-50 that could be updated on top of those, and you're missing any mention of the workflow stuff.
Again, please, don't bother with the database, do it properly with REST or Jira's UI.
Upcoming Trello Events
