I use trello from 2009 and missing an editor for card..lately this missing it's hard to sustain...is there some power up or I need to try some trello alternative?
Hi @Elena Caramanico 👋 Do you mean that instead of using Markdown to format, say, card descriptions, you want a rich text editor toolbar to use in Trello?
Thanks for confirming! There's no power-up at the moment that adds a rich text editor to Trello. Not sure if you're open to using Markdown, but you can use the basics to format your card description and comments. For example:
* Enclose the text with two underscores or asterisks to italicize ( _hi there_ or *hi there* )
* Enclose the text in double asterisks to bold it ( **hi there** )
If there's specific Markdown formatting you need, you might be able to find it here: https://www.markdownguide.org/basic-syntax/
Let me know how this goes. In any case, the Atlassian team may already received this as feedback. 🙂
the markdown is known but for the moment it has become too unsustainable in time .. for this I was hoping there was a power up or another solution
I see, thanks for clarifying. I did a quick search and the Atlassian team has received feedback about this in this thread, so they're likely aware that this is something you and other users are looking for. 🙂
@Elena Caramanico There's a powerup that allows this for comments, not sure if there's also something for the description:
https://trello.com/power-ups/5982d4cc19d3e5f7c657c71b/advanced-comments-by-aj
