×Hi @Ari
You can create an automation to add an existing checklist to all new cards with automation:
This is what my "Test Card" looks like:
From then on, all newly created cards will have that same checklist added to them in that board across all lists.
If that helps, please don't forget to accept this as the solution!
Let me know if you have any questions.
hey @Josh_Unito not sure if you got my reply i said unfortunately i still got the same response is there a way to show you my screen? or maybe it wont work because im in trial
@Ari Can you take a screenshot and add it here in the thread? I tried again in a free account and I was able to go through those steps.
From the board you're working in, you click on "Automation" (the lightning bolt symbol) then Rules:
Next you click Create automation:
Then, Add Trigger:
Hey @Josh_Unito my prntscrn isnt working so i had to do it the long way. i followed every step as you said and here are the images
Hey @Ari I just tried it again and it worked. It might be case sensitive so make sure you copy paste the exact name of the original card and the checklist.
Hey @Josh_Unito still not working for me i did the exact steps like you said but did you have to go to checklists and click the checklist from card TEST CARD 2.0?
@Ari I'm not sure what else to suggest, I recorded a quick video showing you exactly what I did (no audio)
@Josh_Unito https://vimeo.com/954490978/95bd19e4fa?share=copy heres a video please confirm what i did is correct
@Ari in the video you shared, I didn't see a Test Card 2.0, which is what your rules referenced.
The automation also won't retroactively add a checklist to existing cards, only new ones you create.
@Josh_Unito it was when a card is added to a list .... by me. guess not like when a card is created to the board by me
