Hi
I want to send a automated message via slack and tag a person.
I found this
To post a message to a direct message, you need to find the recipient's Slack member ID in Slack:
Go to the direct message channel and click on their profile
Click on the View full profile link
Click on the ellipsis (...) More icon
Click on the Copy member ID button
Paste the member ID into the "Slack channel" field in Butler's Slack action"
but im stuck on step 5.
If I add #memberID in the message it will show the member id not the name.
If I add to to the #channel - no message is send.
I have a #channel and there I want to @person but that doesn't seem to work.
I only shows "@person - automated message" in stead of "taggedperson- automated message"
how do I tag?
Hi Arjan! I'm afraid we don't have a way to tag a person in a Slack message that's sent to a specific channel, but there a few other options worth considering.
The steps above would let you send a DM to that person. You'll need to copy their Slack ID into the channel field in Trello, like this:
Another option is to ask that person to set up Slack notifications from within Trello. To do this, they will:
This will send them a notification in Slack whenever they're mentioned in a Trello card.
Thank you for your reply.
To bad my idea for tagging some one in a channel is not possible. (Yet)
Hopefully trello will implement this in the future.
For now I will just send them a DM.
This works beautifully. Thank you!
The following format works for me: <@memberID> for tagging a specific person with their Slack member ID :)
Create a Rule > Set up Trigger > Action: Slack Message
Here you go:
