move a card based when device connects to wifi
Matt Geerdes February 9, 2021
Hello, is it possible to move a card when I connect to wifi?
Thank You!
Matt
Iain Dooley
February 9, 2021
@Matt Geerdes if you have an iPhone you can do this using a Siri automation + Butler. You can have a Siri automation run when you connect to a particular wifi network, and you can trigger that to create a card with a particular name in a particular list. You can then use Butler to trigger when that card with that name is created in that list and move the card you want to move (and archive the trigger card to tidy up)
Matt Geerdes February 10, 2021
Hello Iain!  How does the Siri automation trigger the card in Trello?  Thank You! Matt
Iain Dooley
February 11, 2021
Vero Rivas
February 9, 2021
Hi @Matt Geerdes
   Yes, without problems, if you ask for the application when you are logged in with the same user, what you move in the application, it will be reflected in the desktop application
   I hope I solve your doubt
Cheers
Hello Vero, I do not understand your answer, do you have an example? Thank You! Matt
Like • Vero Rivas likes this
Vero Rivas
February 9, 2021
I have assumed that you mean to move a card with the trello application from your mobile and when you have wifi to use the application, it is correct, but what do you mean?
I'd like to auto move a card from one list to another when my phone connects to my wifi network.
