How Atlassian uses Jira to manage risks and compliance obligations - Part 2
41 comments
jimmi.handoko September 17, 2019
@Guy for a starter like me, is there any steps that I can follow and easily understand? I usually use Confluence for documentation, raise issues / incidents in JIRA. But I want to know where and how to start for kicking off RCSA establishment within JIRA. I mean like a GRC in JIRA for dummy. Haha.
Guy
September 18, 2019
@jimmi.handoko reach out to me directly - guy@atlassian.com and let's talk - might be a good idea to get your Jira admin on the call as well.
Guy
September 18, 2019
@Shuichi Sakai We built an app internally - I think that there are a couple on the app store that do the same thing.
jimmi.handoko September 18, 2019
Thanks @Guy , will be in touch soon.
Miguel Silveira
@Guy Thank you for this.
It appears that you only show the screens of the existing transitions.
Some custom fields from the first part are missing, can you specify the screens and fields for issue creation on workflows.
Nevertheless, this will be incredibly useful to multiple GRC teams! Thank you
Scott Margolis
November 19, 2020
@Guy
This is absolutely spectacular and helpful!!  Thank you very much.  I'm going to see what I can do with NIST following this great approach you've laid out here.  Thank you
-Scott
Muhammet Ayal
Hi  @Guy ,
Thanks for the sharing.
Should I customize / seperate every creation screen according to Part1's fields?
or
Every issuetype schould have one create screen?
What is your suggestion / best practice?
Deon Aiken
March 9, 2021
@Guy Is there any more information you can share regarding this implementation of JIRA GRC? My company is using this as our compliance tool but really needs some additional information on how to best use the different issue types and understanding the workflow. Any guidance or information you can offer would be helpful.
Gyuri Kim
May 5, 2021 edited
Hi @Guy
Is part 3 there in the draft stage? I followed part 1 and part 2 setups on our JIRA cloud but I still feel very blurry about this. It would be great if I can see some implementation examples of how to present control objectives on JIRA. I hope Atlassian Sydney open a meetup for GRC in future :)
Like • Lesley Anderson likes this
Jordin
September 13, 2021
How do you recommend we trigger risk reviews annually or after a certain period of time? I would expect some sort of notification being sent out once a date has arrived to trigger a re-evaluation of the risk.
Lesley Anderson
September 22, 2021
@Jordin I'm experimenting with the policy workflow and have set up project level automation to transition the policy jira back to in progress 11 months after the last resolution date.
Muhammad Fahad
January 14, 2022
Hi @Guy ,
Thanks for right in detail. It's good and useful. Just wondering if you are writing more on the control objective. Looking forward to your response. Thank you
We will be sharing information on the control objectives that we have and how we went about building them - we have really enjoyed the risk and compliance journey so far and want to share our travel stories.
Nick Gyorfi
July 20, 2022
@Guy Would be awesome to pull in the Security Controls Framework CSVs, they map the majority of control frameworks :)
Apryl Harris
Hi.
Can you advise/suggest one workflow that might work for issuetypes for compliance type Jira projects? D
Victor Galli August 22, 2024
Hey @Guy, do you have any additional information that you're able/willing to share about how this has been going for your team?
Have y'all changed anything or started doing anything new since the Part 1 and Part 2 articles were first written?
Ignat Alexeyenko February 27, 2025
This is an awesome deep dive into what you can build in Jira for GRC! Seeing how flexible Jira is for managing risk and compliance is really inspiring.
We’ve taken a similar approach and built a native solution - Cat the Compliant - designed to streamline audit workflows, compliance tracking (SOC 2, ISO, etc.), and reporting, all within Jira.
Would love to hear what you and the Atlassian team think! First five replies get a free license (Atlassians always free, of course 😉).
Ignat
