Advanced Road Map trialling on Cloud
Roy
December 10, 2023
Your help is much appreciated.
I am looking for a solution to align work (tickets) with organization level categories. Advanced Road Map seems to do exactly that.
1. Is it available on Jira Cloud ? (premium subscription).
    Market place states that it's only available for Server and Data Center licenses. But this link doesn't have this limitation Advanced Roadmaps Guide | Jira Software | Atlassian
2. If it is available on Cloud premium, how do I start a trial?
thank you
Antuan Sammak
December 10, 2023
Hi @Roy
1- you are correct, Advanced Roadmap supports Jira Cloud and they are part of Premium subscription only. they are not part of Free no Standard types.
2- to enable them, you need to have admin access on Jira instance then hit settings button from top right corner
select Billing
you will land on a page showing the products you are subscribed to, one of the is Jira Software
click on Manage next to Jira Software
click on Change Plan
Select Premium and follow the steps.
once enabled you will have Premium plan enabled for 30 days free trial.
Advanced Roadmap will be accessible from top menu bar in your Jira, click on Plans.
Hope the above helps.
Roy
December 13, 2023
Thank you!
Mo Omar February 2, 2024
Hi there,
We've recently switched over to trial the Premium Plan on our Cloud instance, to trial Advanced Roadmap. However, when I select the available plans as you described in your previous instructions I didn't see 'Advanced Roadmap' anywhere. I've also gone directly to the Market Place page for this app and it still only offers the Data Center/Server option. Could you give us further instructions on how to trial the product?
Many thanks
Antuan Sammak
February 5, 2024
Hi @Mo Omar
as per your screenshot, you are subscribed to Premium plan.
so now you have to head to your Jira instance and from the top navigation bar you should see Plans, or if you are on a small screen then you will see More and upon clicking on it you will be able to see Plans.
once you click on it, i would recommend you to try the option of creating sample plan which should give you a good insights of this feature and how it can be structured and used.
Mo Omar February 6, 2024
@Antuan Sammak  Thanks for your reply, I've now located where it is. Many thanks for getting back.
Michael Yaroshefsky - Visor for Jira
October 11, 2024
Hey @Roy if you're interested in an alternative to Advanced Roadmaps give Visor (our app)  try. You can use it to build Jira roadmaps with milestones, and share with stakeholders too. Here it is - we have a free plan too.
https://marketplace.atlassian.com/apps/1226209/visor-spreadsheet-gantt-chart-for-jira-with-excel-export?tab=overview&hosting=cloud
