Estimates in Advanced Roamaps doesn't update ticket estimate
Channing Childs June 24, 2020
I love how easy it is to create Epics and Stories in Advanced roadmaps but the Estimate field does not transfer to the ticket in either the Story Points or Original Estimate field.
If I create a ticket via the Create button with a Story Point that does not translate to the estimate field.
If I add an original estimate time it does show on Advanced Roadmaps - yay! But if I change the Estimate on Advanced Roadmaps and save it. There is no update in the ticket.
Is this a bug? Oversite? Or is there another way I should be managing estimates in ticket so what I change in one area is reflected in the other?
Pete Morris
June 24, 2020
Hi @Channing Childs !
I'm super happy to hear you're enjoying Advanced Roadmaps!
Depending on your chosen estimation method (Cog next to the plan's name -> Scheduling -> Estimation), Advanced Roadmaps will show either a "Story points" field or an "Estimates (h/d)" field. "Story points" maps directly to the "Story points" field on the issue once changes are committed via the Review changes dialog. "Estimates (h/d)" actually maps to "Time remaining" which can be found in the "Time tracking" section on the Jira issue.
The confusion here arises from the fact that updating "Original Estimate" the first time will automatically transfer to the "Time remaining" field, but subsequent changes do not. Advanced Roadmaps does not reference the "Original Estimate" field at all.
I hope that helps. Please let me know if you have any other problems.
Peter Reiser
June 25, 2020
@Pete Morrish
We are using Advanced roadmap to plan our estimation "budget (h)" of a ticket.
We need to set the original estimate as the "budget (h)" and then we book time spent (h) against  original estimate (h) to measure budget (h).
We cannot use "Time Remaining" as the budget (h).
So I think to correct behaviour would be to set "Original Estimate" if it's empty.
With the current implementation we have to manually set the "Original Estimate" per ticket which makes the use of advanced roadmap pretty useless :-(
I think this is a pretty standard use case and should be covered by Advanced Roadmap
Like # people like this
Channing Childs June 25, 2020
@Pete Morris thanks so much for clarifying. This should be updated in the documentation as I could not find this anywhere.
I'd love help with my question here too!
https://community.atlassian.com/t5/Advanced-Roadmaps-questions/Target-Dates-vs-Start-Dates-in-Advanced-Roadmaps/qaq-p/1415149
Like Jo Beck likes this
Andrea Santi
March 1, 2021
We also need to have the estimate written into "original estimate". Can this be made configurable in any way??
Like Kelli Bryant likes this
Tom
Hi all, any update to this? Can this be done by some automation rule?
Garth Hume
Fixing this would be awesome.
Kelsey McDowell September 1, 2021
Following
Garth Hume
We have built an automation that copies the Time Remaining to the Original Estimate field if the Original Estimate is blank.
Panteley Kramarski
September 23, 2021
Following
Annie Ioceva _Nemetschek Bulgaria_
Hi @Garth Hume and all, can you share how did you manage to copy the RTE to OTE?
We have stuck between Advanced Roadmaps - which do not update the OTE and the Scrum boards which do accept only OTE as an estimate. So unless we find a way to copy the RTE to OTE - using Advanced Roadmaps will generate a huge manual overhead.
Hopefully, your approach will work in the cloud!
Thank you in advance,
Annie
michaelheiml
November 8, 2021
Hi, we are facing the same issue. @Garth Hume any chance you could share your solution please?
Henk Smets
same issue here
Vedant Kulkarni_Trundl
September 13, 2023
issue still persists in September 2023. Estimate hours are written in the Time Remaining field instead of the Original estimate
Like Benjamin Grab likes this
Garth Hume
Hi, we used a Jira automation to do this.  We created a custom field called SWAG which will set the Original estimate and override the Time Remaining if Time Remaining is blank.  We do this using Jira automations.  the SWAG field can be used in Advanced Roadmaps.  It's slightly clunky, because you have to apply changes so the automation can fire.  It works OK as you are likely not estimating your size and planning your timeline at exactly the same time.  It's basically just a workaround for a poorly designed function in Jira.
Benjamin Grab
September 14, 2023
Hi, is there any time estimate for this option? It was requested in 2020 and after 3 years it's still not possible to use this useful field.
