×I use cloud but i have ask that how i get bulk removed task back into Advanced Roadmap view?
Here i can reed how to remove from scope table (https://confluence.atlassian.com/jiraportfolioserver/removing-issues-965567130.html).
Hi @Urmo Luts,
Navigate to your plan settings (next to the plan name, click the cog icon and select configure).
Then, from the left hand side menu, select removed issues. You should be able to find them there and re-include them in your plan.
