×Hello
My organisation has opted for an agile approach. We use OKRs (Objectives and Key Results) to ensure our work is aligned to our strategy. We would like to better understand to what extent Advanced Roadmaps could help us to record our work and monitor progress of work against the OKRs.
We’d very much like to have a conversation with another agile organisation who already uses Advanced Roadmaps to manage their OKRs.
Any tips or pointers would be appreciated.
Many thanks
Hi @Erwin Juenemann
Advanced Roadmaps basically add additional levels to the hierarchy. As a result, you can view all your Objectives, Key Results, and Jira Issues in a structured way. I've put together a screenshot for you of how it may look like:
You can build it in a couple of easy steps:
1. Create new issue types for "Objective" and "Key Result".
2. Adjust your issue type hierarchy, so that your Objective and Key Result would be on the top.
3. Go to the "Plans" and build your Advanced Roadmap.
However, it would be best if you kept in mind that the OKR monitoring and reporting capabilities would be pretty limited. Here are some of the additional perks, you can get with the dedicated plugin - OKR Board for Jira by Oboard:
Let me know if you'd like to have a demo. I'd be happy to help!
Hey @Margo Sakova - OKR Board for Jira by Oboard - Thanks for the info. I'm exploring alternative ways to effectively manage products alongside the OKRs. Given the limitations in Jira and in Advanced Roadmaps to use hierarchy structure for Components and releases, in addition to the absence of Program grouping, I found this very challenging. Do you have any suggestions or insights on how to effectively display and manage product status? Thanks
Hi @Shiri Feldman
You're absolutely right! Managing OKRs in Jira can be quite challenging. Unfortunately, none of Jira's out-of-the-box features are fully suitable for applying the OKR framework.
I've assembled a demo screenshot illustrating how you can structure goals across different products in the Oboard OKR plugin for Jira. If you have fewer than 10 users, it's entirely free. You can create as many OKR levels as you'd like, build groups uniting teams working on each product, link your Jira issues, and track the progress.
Regarding native Jira functionality:
Advanced Roadmaps appears to be the most reasonable option for OKRs, provided you have Jira Premium.
Alternative options for the Standard subscription include creating custom fields for your OKRs or setting up a dedicated project, where you use epics as objectives and stories as key results.
I hope this information proves helpful 🙂
