STATUS field doesn't work as drop down in our JIRA portfolio view. Any help
Swarna Chilakala April 15, 2021
Another pain point during status review meetings is...not being able to see the options in the STATUS field drop down and not being able to update them within Portfolio view. Anyone has suggestions?
Yes the drop down values differ based on the Issue Type.
Angus Russell
April 15, 2021
Hi @sw ,
Updating status from the plan is a frequently requested feature, and something we're looking into.
For some context, the reason it's not currently possible is because many status-change workflows have required fields that must be set, and we don't yet have a good way to deal with those cases.
If you want to be kept up-to-date about the status of this feature you can follow it here - https://jira.atlassian.com/browse/JSWCLOUD-20940
Thanks for the feedback :)
Angus
Thanks for the response @Angus Russell , appreciate it. But can you tell me how many votes does this need before it can be looked at?
Angus Russell
April 15, 2021
@Swarna Chilakala it's one of our highest requested features, and we're already investigating how it might be possible to do it. However, I can't give any time estimate for when this might be done, because the investigation in progress could still yield blockers and the work to implement it has not been scheduled.
Angus
Swarna Chilakala April 19, 2021
cc timjones@pinterest.com
nbhatnagar@pinterest.com
@Angus Russell Thank you so much for prompt response
pinterestvideodownloader cc
November 28, 2022
Hey, Thanks for sharing it. Can someone please review the Pinterest Tool with a feedback about it.
