×I have enabled the Advanced Jira Roadmap and in Timeline Plan view, only a few fields like Assignee, dates etc. fields are available. How do I show existing fields used in my Jira Project (including custom fields in Jira project associated to the tickets)?
Re: Advanced Roadmaps ....
To add and view custom fields in your plan:
Select Plan settings from the left side navigation.
Choose Custom fields to show you all of the custom fields currently in your plan.
Select Add custom field in the upper right corner, then search for the fields you want to add.
Use the Add fields button to finalize your choice.
More details ...
There's also a link on there with more information about "Timeline" tool under projects (which isn't direcly connected to 'advanced roadmaps (Plans)')
I hope this helps.
Tim C
