×I have spent a fair amount of time troubleshooting this, and have ruled out fixVersion (all stories have it) and Roadmaps' date filters.
I believe what is happening is that my company's (admittedly non-standard) workflow has three levels of done: Client Review, Ready for Deployment, and Done.
Roadmaps appears to only see the stories that are Done, and completely ignores Client Review and Ready for Deployment stories. They literally disappear from the plan for two steps of our workflow before popping up again.
Can this problem be confirmed & addressed? I'm advocating to change our workflow, however if Jira allows 3 different types of Done, then Roadmaps should respect that, and I see this as a Roadmaps bug.
Hi Stephen
Sorry to hear you're having problems with issues disappearing from the plan.
We've seen this happening with a few customers and it's usually caused by the custom workflow not setting "resolution" field, when transitioning to a "Done" status.
You can test this by looking next to the "Done" status in the issue view in Jira. If it has a green tick next to it, then the resolution is set. If it's blank then the resolution is not set.
If the resolution is not being set, Advanced Roadmaps is unable to know when an issue has been resolved so it will remove these issues from the plan (ignoring the setting for "include completed issues for x days", as this is based on "Resolution", not "Done").
To fix this, you'll need to add a post function to your custom workflow on the transition that leads to "Done" status to set the resolution field. Also don't forget to add a post function to unset the resolution when transitioning back from a "Done" status too.
There's more information on this here: https://confluence.atlassian.com/cloudkb/best-practices-on-using-the-resolution-field-968660796.html
Hope this helps
Mark,
Thanks for the info re: root cause - it does appear that my missing issues have no resolution set, which is causing them to elude Advanced Roadmaps.
I created a test issue and tried editing the resolution via bulk edit, but it seems it's not possible to edit the field directly without using a transition. Not knowing all the ramifications of playing with the resolution field, I hesitate to change our workflow at this time, because that will impact all of our issues in progress.
I'm sure there's a way to test this without impacting our real work issues, but I lack the Jira admin experience and time to figure it out. Instead, I'll review the prototype solution that Amy offered to share, which will hopefully fix this situation in a future release.
Thanks, Stephen
Hi Stephen
Under configuration settings > Issue Sources you can set 'completed issues' to display for a time period, try that and see if that fixes it.
Mine defaults to 30 days.
Unfortunately this setting does not help in my situation. I'm using the same 30 day period, and these issues are within the window.
Indeed, the only action required to make them reappear in my roadmap is to transition from one of the two affected Done sub-statuses (Client Review or Ready for Deployment) to Done.
