Sign up Log in
when grouping by components on jira advance roadmaps it doesn't bring in the child tickets.
Kaushal Patel
April 20, 2022
is there a workaround for this or does the component need to be added to each project and each ticket?
Curt Holley
April 20, 2022
HI @Kaushal Patel
Yes, for anything to appear in the grouping, it has to have the relevant field populated (in your case, component).
You could set up automation to populate components on to Stories etc from their Epic, but that still requires the Epic having the data.
Unnikrishnan Ramachandran April 22, 2022
@Curt Holley  I have the similar issue when Grouping By Releases.
It brings the "Epics" under a release, but does not bring the "Stories" under the Epic.
Any suggestions?
Curt Holley
April 25, 2022
@Unnikrishnan Ramachandran So is it not that the stories do not have the release in the fix version field?
Unnikrishnan Ramachandran April 25, 2022
@Curt Holley Thank you! that helped. I was assuming that the Epic - Story relationship would implicitly tie the stories to the Fix Version field.
I explicitly updated the story to have "Fix Version" and it worked.
Like Curt Holley likes this
