Hi All,
I need help with below issue …i’m getting in jenkins one of job i’m running
Gradle version :- 4.5 i’m using in server
java version :- 1.8 and 13 both using in jenkins and also in server and for below task i’m using java8 version to run but when i execute the job in jenkins it showing java13 in logs and java13 version i’m for other job in jenkins
FAILURE: Build failed with an exception.
* What went wrong:
Could not determine java version from '13'.As you can see below jenkins job showing logs is using jdk-13 it should use java1.8
Even i have use different gradle version also 6.7 in that case also it showing same error
[Netbanking] $ /bin/sh -xe /tmp/jenkins1529297276379477004.sh
+ echo /opt/jdk/jdk-13
/opt/jdk/jdk-13 ===> because of this showing my job is failing it should show java1.8
+ which java
/opt/jdk/jdk1.8.0_291/bin/java
+ java -version
java version "1.8.0_291"
Java(TM) SE Runtime Environment (build 1.8.0_291-b10)
Java HotSpot(TM) 64-Bit Server VM (build 25.291-b10, mixed mode)
Below is the details in server i'm using
Two path showing in server
ls /opt/jdk/jdk1.8.0_291
ls /opt/java/openjdk/
Below is the path of java which using in jenkins
root@bfdbda8e4489:/# ls /opt/jdk
jdk-13 jdk-15 jdk1.8.0_291
Different version using for different jenkins jobs
yes its already been configure in Global Tool Configuration with multiple java version has been added and in project i have selected java 8 to run my job and its again fail
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Apply agile practices
Transform how you manage your work with agile practices, including kanban and scrum frameworks.
Learning Path
Configure agile boards for Jira projects
Learn how to create and configure agile Jira boards so you can plan, prioritize, and estimate upcoming work.
Jira Essentials with Agile Mindset
Suitable for beginners, this live instructor-led full-day course will set up your whole team to understand how to use Jira with an agile methodology.
