×Hi,
this Video (by Atlassian) shows a workflow with the statuses/column:
– Todo
– Develop
– QA
– Approved
– Done
How do i configure my greenhopper like this? I just bought the 30 days trial and could not find any "kanban options".
Thanks for helping,
Fabian
Solved! Go to Solution.
Isn't the Kanban view option just the 'compact view'?
This will just mean that subtasks are not specifically connected to their parent issues. The whole taskboard acts as one Kanban board.
But you will need to define workflow states for Kanban as they dont come out of the box
I though i can select/import a build-in configuration. So let me try to build this for myself.
You will need to define the workflows first, as the defaults are only open, in progress, resolved. You will need the additional ones added for QA, Approved etc..
Then under Admin->Greenhopper->Custom Templates you can define a new one for Kanban
At the bottom of that screen is the taskboard mapping. This is where you create the Kanban columns and assign the respective JIRA workflow states to them. Notice they don't need to be a 1:1 mapping. Some JIRA workflow states may not be visible, others may be joined into 1 Kanban column. It is quite flexible
Just an FYI :)
The compact view (Kanban view) is the view that shows the constraints that have been placed on the columns, i.e. in response to being over or under capacity, the column is shaded accordingly(yellow/red). These constraints do not show up on the other Task Board views and can only be set from the Compact view. When in this view hover mouse over top the column and will see the familair tool symbol (cog), click on this and choose column constraints.
The constraints and the visualisation of them is a key concept in Kanban, so the compact view is the only complete Kanban view. (currently - rapid boards add more)
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Apply agile practices
Transform how you manage your work with agile practices, including kanban and scrum frameworks.
Learning Path
Configure agile boards for Jira projects
Learn how to create and configure agile Jira boards so you can plan, prioritize, and estimate upcoming work.
Jira Essentials with Agile Mindset
Suitable for beginners, this live instructor-led full-day course will set up your whole team to understand how to use Jira with an agile methodology.
