×There often arises a need to export Jira issues for various purposes like reporting, analysis, or backup. This article explores the different methods to export Jira issues to Excel and CSV formats natively, and using Jira plugins.
Exporting issues to Excel is straightforward in Jira. Here’s how you can do it:
For more flexibility, especially when integrating with other software, exporting to CSV is ideal. The initial steps are similar to exporting to Excel. After filtering your issues, select the 'CSV' format in the export options.
Planyway is a powerful add-on for Jira that broadens the horizons of project management with advanced roadmaps, workload management, calendar planning and time tracking. So, if you’re looking for a way to enhance project management capabilities, Planyway is perfect for that. And once you decide to export the data both crated in Jira and in Planyway, it can be easily done by clicking Export button on any of the chosen views.
Mary from Planyway
Customer Support Manager at Planyway
Planyway
Kazakhstan
62 accepted answers
11 comments
