Sign up Log in
convert a issue to a subtask using scriptrunner for jira cloud
Alex Sprague
Recently i ran into a dilemma. I am trying to take a issue that is created and convert it to a subtask of a different parent issue as part of a postfunction.
I was able to script a way to generate the key for the parent issue using the following code. In Jira we have the option to convert a issue to a subtask. The code below generates my parent ticket id as the queuedissueparent. What would  need to be done to take a task and then convert it to a subtask that is linked to the queuedissueparent?
// get custom fields
def customFields = get("/rest/api/2/field")
.asObject(List)
.body
.findAll { (it as Map).custom } as List<Map>
// get issue type
def issuetype = get("/rest/api/2/issue")
.asObject(List)
.body
def projectKey = issue.fields.project.key
def inputprojecttype = customFields.find { it.name == 'PIA Project' }?.id
def input1 = issue.fields[inputprojecttype] as String
if (input1 != 'UNKNOWN') {
if (input1 == 'Rapid Design Engagement') {
def queuedissueparent = 'BPIA-1132'
else
if (input1 == 'Fixed Wireless') {
def queuedissueparent = 'BPIA-1133'
else
if (input1 == 'Head End') {
def queuedissueparent = 'BPIA-1134'
else
if (input1 == 'Conduit Design') {
def queuedissueparent = 'BPIA-1135'
else
if (input1 == 'Subdivision GIS Design') {
def queuedissueparent = 'BPIA-1136'
else
if (input1 == 'Business Readiness') {
def queuedissueparent = 'BPIA-1137'
else
if (input1 == 'OSP') {
def queuedissueparent = 'BPIA-1138'
else
if (input1 == 'Confluence Space Standardization') {
def queuedissueparent = 'BPIA-1139'
else
if (input1 == 'Contracts') {
def queuedissueparent = 'BPIA-1140'
else
if (input1 == 'Change Orders') {
def queuedissueparent = 'BPIA-1141'
else
if (input1 == 'Department User Dashboards') {
def queuedissueparent = 'BPIA-1142'
else
if (input1 == 'Departmental Dashboards') {
def queuedissueparent = 'BPIA-839'
else
if (input1 == 'EPP') {
def queuedissueparent = 'BPIA-1143'
else
if (input1 == 'Feasibility') {
def queuedissueparent = 'BPIA-368'
else
if (input1 == 'Member Dashboards') {
def queuedissueparent = 'BPIA-1145'
else
if (input1 == 'Member Project Information Updates') {
def queuedissueparent = 'BPIA-1161'
else
if (input1 == 'Regional Dashboards') {
def queuedissueparent = 'BPIA-1146'
else
if (input1 == 'Revamp the PIA Request Process') {
def queuedissueparent = 'BPIA-1147'
else
if (input1 == 'IMS Training Process Documentation') {
def queuedissueparent = 'BPIA-1144'
else
if (input1 == 'IMS Member Rollout') {
def queuedissueparent = 'BPIA-197'
I think the link would be done using the following code. I am just not positive how to actually convert a issue to a subtask using scriptrunner for jira cloud.
// link issue block of code
// Specify the source issue
final sourceIssueKey = issue.fields.key
// Specify the target issue
final targetIssueKey = 'queuedissueparent'
// Specify the link type to use
final linkType = "Relates"
// issue link
def link = post('/rest/api/2/issueLink')
.header('Content-Type', 'application/json')
.body([
type: [ name: linkType ],
outwardIssue: [ key: sourceIssueKey ], // This is the issue that the link 'starts' at.
inwardIssue: [ key: targetIssueKey ] // This is the issue that the link 'finishes' at.
.asString()
Kate Kabir
March 11, 2021
Hi Alex
I can confirm that there is no API to convert an issue into a subtask. You can create the subtask. Here is the documentation on how to create subtask.
The Build In Create Subtask as documented here which you could add into your workflow onto the Create transition for when the issue is created in order to automatically create the sub-task that you require below the issue.
The documentation page linked to the Create Subtask post function provides some step by step instructions on how to configure this post function inside of a workflow that you will be able to follow.
I hope this will help.
Thank you
Kate
Alex Sprague
@Kate Kabir Thank you for the reply. This wasn't exactly what i was hoping for an answer but i figured i could go the create subtask route,
