hey how do i post a comment as a different user using jira api (impersonisation)
Mediga Vishal Vardhan September 12, 2024
i want to know how to perform
impersonisation with jira api
Kishan Sharma
September 13, 2024
Hi @Mediga Vishal Vardhan
Atlassian does not support impersonation through the Jira REST API. However, Atlassian Connect supports user impersonation using the JWT Bearer token authorization grant type for OAuth 2.0. This authorization method allows apps with the appropriate scope (ACT_AS_USER) to access resources and perform actions in Jira and Confluence on behalf of users. You can refer User impersonation for Connect apps  for more details.
Hope this helps.
Mediga Vishal Vardhan September 14, 2024
that worked thanks @Kishan Sharma
Like Kishan Sharma likes this
