Assets - Concatenated field
Vicky Pelgroms
March 12, 2025
Is there a way to create a kind of concatenated field in the assets?
We have an object type "Building", this consists out of some fields like "FullName" and "Code".
When we want to change the building of a laptop, it would be convenient to search for both "FullName" AND "Code". I know you can put these fields together with an automation rule, but is there a way to make a kind of "calculated" field that is selectable in the assets?
Thank you for your suggestions.
Vicky
Pasam Venkateshwarrao
March 12, 2025
Hi @Vicky Pelgroms
Welcome to the community, to implement a concatenated field
In your JSM project, add a new custom field of type "Assets objects".
Configure the field:
 Select the desired asset object schema,Within the "Filter Work Scope (AQL)" section, write an AQL query to specify which attributes from your asset objects you want to include and how to join them together using the "CONCAT" function.
Example AQL query for a concatenated field:CONCAT(asset.name, ", ", asset.serialNumber, ", ", asset.location)
For detail explanation refer the doc
March 14, 2025
@Vicky Pelgroms Have you seen this doc is it helped to you
Vicky Pelgroms
March 14, 2025
Hi @Pasam Venkateshwarrao
Thank you for your response. I found the suggestion you did, and this works great on JSM forms. But I want to use it in the assets itself.
ex where I want to use it (see Building field):
March 15, 2025
@Vicky Pelgroms then you can create custom field Building as a "select List (cascading)" type then it will show like this
Screenshot 2025-03-16 at 12.03.13 AM.pngScreenshot 2025-03-16 at 12.03.01 AM.pngScreenshot 2025-03-16 at 12.02.38 AM.png
