Using the Atlassian Remote MCP Server beta
We’re excited to share that our Atlassian Remote MCP Server is now available as public beta in approved MCP clients.
If you haven’t yet, please make sure to visit this page to learn about Atlassian’s Remote MCP Server.
Instructions
In products that support remote MCP servers, fill in https://mcp.atlassian.com/v1/sse as the server URL to create a connection.
Setting it up in Claude.ai
Go to https://claude.ai/settings/integrations to manage your Claude integrations.
If you are part of an organization, you may need your administrators to set up the integration before you can use it.
Click "Add integration".
Add our remote MCP server details. Please use https://mcp.atlassian.com/v1/sse as the server URL.
Go to "New Chat" in Claude and click “Connect” in the "Search and Tools" menu.
Select the Atlassian site you would like to access, review permissions and accept if everything looks right.
Back to "New Chat" in Claude, and select tools to use.
You are ready to go! Your Claude now has access to your Atlassian site through the tools you've selected.
Setting it up in desktop applications
Please see instructions here if you are looking to use the MCP server in a desktop application such as your IDE.
Feedback and support
If you have any feedback, suggestions or questions, please visit our support portal here.
134 comments
_A9_ William Kennedy
I love how fast you are all moving here. I left a post-it at team asking "jira mcp server when?" thinking it would be a while!
Like # people like this
Jay Kelner
Can you guys add some instructions for configuring this agnostic of which MCP client is being used? MCP is an open protocol and some of us want to use Cursor or other MCP clients :)
EDIT: as far as I can tell, there is only one product this works with right now which is Claude Teams.
Firstly, many MCP clients like Cursor do not even support authorization with remote MCP servers yet. (authorization was only added to the MCP spec about a month ago).
But secondly if I try to use the mcp-remote community project to try to bridge that feature gap, e.g. to get Cursor connected, the authorization flow fails like so:
The redirect URI is not allowed, the URL is not part of Atlassian whitelisted domains for registered MCP Clients.
Redirect URI http://127.0.0.1:3334/oauth/callback
This error message raises the question of what redirect URIs are whitelisted by Atlassian, and I suspect there is only one such callback -- the claude.ai callback, i.e. https://claude.ai/connect/atlassian/callback.
If so, that makes it difficult to use this with any product besides Claude Teams.
EDIT 2:
They've added support for a localhost callback. It works with mcp-remote now. The Atlassian team moves fast. More info over at https://community.atlassian.com/forums/Atlassian-Platform-articles/Atlassian-Remote-MCP-Server-beta-now-available-for-desktop/ba-p/3022084
Well done and thank you Atlassian folks!
Matthew
May 1, 2025
+1 to adding agnostic instructions, and thank you to the teams for launching this!
Albert Nerikat
May 1, 2025
how do i integrate this with n8n?
Update: I was able to successfully integrate n8n and atlassian jira using the GitHub mcp server. Please see the below thread.
https://www.reddit.com/r/n8n/s/P12nVSHcQd
Vaishali Jain
May 1, 2025
How to add this mcp server in Claude or github copilot or cline? How do I pass in other parameters required for authentication?
I need help in configuring Atlassian MCP server  as the server URL in Claude Remote MCP server. Where can I find step by step instructions?
Qiaochu Yang
May 1, 2025
I configured the remote mcp in cursor like this:
 "mcp-atlassian": {
"command": "npx",
"args": [
"mcp-remote",
"https://mcp.atlassian.com/v1/sse"
However, the OAuth flow failed — is it because the remote server’s OAuth app doesn’t allow the redirect URL? I’m curious how this is expected to work for anyone if that’s the case.
The redirect URI is not allowed, the URL is not part of Atlassian whitelisted domains for registered MCP Clients. Redirect URI http://127.0.0.1:3334/oauth/callback
Michael Irey
May 1, 2025
Thanks for providing remote mcp server.
Is this open source?
Can you auth with API key?
Arthur Silber
May 1, 2025
Great work!
Do you have planned adding support for custom fields in issues? Background: most people use dedicated fields, e.g. "Actual Result" and "Expected Result" for bug-tickets, and all MCP integrations right now put everything in the description.
Prithveesh Goel
May 2, 2025
Unable to integrate with Copilot. Can someone share the steps to integrate with copilot?
Sergio Behrends
May 2, 2025
@Kun Chen could you share how to connect to the MCP server with other MCP Clients?
As several others above, the MCP client fails to connect due to lack of token, and seems like standard Basic Auth that works with REST API won't work for MCP.
Thorsten Kamann
I haven't the Add more button to add custom integrations. What do I need to do or which plans at Claude support the Atlassian MCP Server?
Stanislav Ivanov
May 2, 2025
Is this only for Claude Enterprise and Team users ..and Max..?
https://support.anthropic.com/en/articles/11175166-about-custom-integrations-using-remote-mcp
The 'normal' paid users doesn't seem to have this option and adding the MCP server in the conf file doesn't do anything really, says auth. failed, but doesn't come any window to authenticate or so.
MJ
May 2, 2025
Configuration procedure worked for Claude.ai, but could not configure it with Claude code.
Authorization flow did not start after adding server
Atlassian Team: Can you please publish process of configuring the MCP server with Claude code and cursor?
Jason Schulz
May 2, 2025
Came here for the same as many of the above comments. The remote mcp server works great in Claude Desktop and I'd love it in Claude Code and/or other MCP clients.
Jiquan Ngiam
May 2, 2025
Hi! We're building an AI agent that completes task across work apps; supports the most recent OAuth MCP protocols out of the box. It's been working smoothly with the most recent MCP remote servers launched, and we'd love for the Atlassian server to work well with it too.
We're running into the same error "URL is not part of Atlassian whitelisted domains for registered MCP Clients" - how can we get into the whitelisted domains?
Client: https://lutra.ai/mcp
Jiquan Ngiam
Lutra AI
Like Roger Abelenda likes this
Atlas Can
May 3, 2025
Really wish this is available to team users and also for external apps.
Like Nick Blake likes this
parthasarathi.u
May 3, 2025
This is how I successfully connected to VS GitHub Copilot. I hope it works for other MCP clients as well.
"mcp": {
"servers": {
"atlassian": {
"url": "https://mcp.atlassian.com/v1/sse",
"transport": "sse",
"command": "mcp-atlassian",
"args": [
"--jira-url", "https://your-company.atlassian.net",
"--jira-username", "your.email@company.com",
"--jira-token", "your_api_token",
"--confluence-url", "https://your-company.atlassian.net/wiki",
"--confluence-username", "your.email@company.com",
"--confluence-token", "your_api_token"
"env": {},
"disabled": false
Kay D.
May 3, 2025
On Claude Desktop (Teams Plan) it fails to see any tickets on any project of mine that is JIRA ITSM. Anyone else having the same issue?
Somil Bhandari
May 4, 2025
I got it to work with CursorAI with the following configuration
 "Atlassian MCP": {
"transport": "sse",
"command": "uvx",
"args": [
"-y",
"mcp-atlassian",
"--jira-username", "<username>",
"--jira-token", "<token>",
"--confluence-username", "<username>",
"--confluence-token", "<token>"
"env": {}
`uv` needs to be installed and accessible at the PATH.
Trucky And
May 4, 2025
Those who use below command, was actually using open source mcp-atlassian by https://github.com/sooperset/mcp-atlassian. Not the official Atlassian Remote MCP one.
to_hoang_long _ Brian _
May 4, 2025
When can this MCP connect to CursorAI?
Pushkar Choupane
May 4, 2025
How do I connect my custom mcp client to this remote-mcp-server of atlassian?
Are there any defined steps for this process?
Michael Simmons
May 4, 2025
Well for the desktop claude you can edit claude_desktop_config.json
And it should look like this. But I don't know the command or the args.
"mcpServers": {
"AtlassianRemoteMCPServer": {
"type": "sse",
"command":""
Ajay _view26_
This is super cool.. I tried to get the current Sprint summary and it works like a charm 👌
Dusan Spaic
Currently MCP is only available for Claude Team & Enterprise plans :(
What is the best way to stay up to date to your next releases of MCP?
