Using the Atlassian Remote MCP Server beta
139 comments
Community moderators have prevented the ability to post new comments.
Thomas Klein
July 3, 2025
 @Kun Chen @Calum Leslie
Sorry to nudge again on this, but do we have any timeline for when the remote MCP server will move out of beta and become generally available (GA)?
Also, once GA, can we expect:
  • inclusion in core compliance programs (e.g. SOC2, ISO27001, GDPR)?
  • support for full SLAs, billing options, and license enforcement?
  • support for Data Residency controls (ideally)?
These are major blockers for enterprise adoption in our case.
Just for reference: Linear released their own MCP server GA on May 1st.
Juha Palomaki
Depending on what you are doing, maybe the jira-cli makes more sense than the MCP. It's open source and seems to work fine at least with Claude Code: https://github.com/ankitpokhrel/jira-cli
Just installed it and added this line to my Claude config ~/.claude/CLAUDE.md
 You have access to jira command line tool for projects and issues in jira
Haven't done much testing, but at least Claude can now retrieve issues, update them etc.
Maxim Shaev
July 6, 2025
Is there a plan to support Bamboo CI/CD by the Atlassian MCP server?
SHUBHAM GUPTA
July 6, 2025
Can we create our AI chatbot and integrate this Atlassian mcp server?
If yes, then could you please give me some info.
norman_hsu July 7, 2025
I follow @Somil Bhandari in thread, but need to remove "-y" for me to work in cursor
Niko
July 7, 2025
Is MCP server only supported for Cloud based Jira or can it work with Data Center Jira ?
Anybody know ? thank you in advance.
Like # people like this
Surajit Nundy
July 7, 2025
How exactly do I use this in Claude Code (not Claude Desktop app where it seems to work fine)?
@Kun Chen
ISSUE BADGE
July 7, 2025
any youtube video available?
Jitendra Vyas
July 9, 2025
How to force it to create Jira tickets in a specific Jira projects only?
jsnkle
July 13, 2025
@Surajit Nundy from your project directory run:
claude mcp add --transport sse atlassian https://mcp.atlassian.com/v1/sse
Then relaunch Claude Code and use the /mcp command. You'll be prompted to authenticate (it will launch a browser for you to login) and grant permissions.
After that you're all set.
Andrian F
July 14, 2025
@Kun Chen Can we use this with Cursor, without specifying an API token ?
sushanth.m
July 14, 2025
I get  [cause]: Error: self-signed certificate in certificate chain when I run npx -y mcp-remote https://mcp.atlassian.com/v1/sse in VSCode.
 Any solution /recommendation on how to fix this ?
Ueslei Lima
July 23, 2025
I'm trying to implement an automated workflow using this mcp server, is it possible to use Api Tokens instead of relying on a browser based authentication request?
Monique vdB
Community Manager
July 23, 2025
Hi all,
Just wanted to flag this note up top:
This community page is no longer up-to-date. Please reference our new comprehensive documentation for Atlassian's remote MCP server
If you have any feedback, suggestions or questions, please visit our support portal here.
I'm going to close this thread since it is outdated.
