New lookup issues fields
Hi everyone!
Last year, we released a new component, Lookup Issues. This component allows users to use JQL to insert a list of issues into their rule by accessing the smart value {{lookupIssues}}. Up until now, these issues have been very limited in what fields are populated. We received a lot of feedback around including more fields on these issues, and we have now released an update which does just that.
You can now access any field that you would normally be able to access on an issue smart value.
Why would you do that?
Those who are familiar with the lookup issues component know how useful it can be. Whenever you want to get a list of issue keys to include in a correspondence, do routine checks on a group of issues, or just get a count of issues matching a condition, lookup issues is the component to use.
However, we previously only allowed access to a basic subset of available fields. This limited the usability of the component. For example, if you wanted to access a custom field on a list of issues, this was not possible. Now, you have full access to all fields, including custom ones, so you can use them however you like in your rules.
How do you do that?
To use the lookup issues action, take a look at our documentation or have a read about it in its community article. The change in functionality means that the issues looked up by this action can be treated like any normal issue, so have a go with the smart values outlined in our documentation
22 comments
W Bot
Fantastic news, thanks to the Atlassian Automation for Jira Team for continuing to innovate an amazing product!
Like • Deleted user likes this
November 30, 2021
This is awesome!  Thanks to you and the team, @Sam Harding !!
Does this close out this suggestion I made, or are there still some unavailable fields?
https://jira.atlassian.com/browse/JRACLOUD-75018
Like • 3 people like this
Curt Holley
So I should be able to get custom date fields, is that right? @sam
As I'm experimenting with such a field, but nothing is coming through.
Using: {{issue.customfield_10298.fullDate}}
FYI, doesn't seem to matter which date format I try
Sam Harding
December 7, 2021
@Bill Sheboy It does! Just closed it out
Cheers
Sam
Like • Bill Sheboy likes this
Sam Harding
December 7, 2021
@Curt Holley it should be able to get custom date fields. Can you verify the smart values {{issue}} and {{issue.customfield_10298}} to see whether the smart value structure is correct? I am not sure that the 'issue' part of that is correct in the context of using a lookupIssues smart value.
I would expect the smart value to be something like
{{#lookupIssues}}{{customfield_10298.fullDate}}{{/}}
Cheers
Sam
Curt Holley
Correct @Sam Harding working now I've made it {{customfield_10298.fullDate}}
Thanks for that.
This is a great enhancement of the Look-up issues action.
Italo _Modus Create_
December 8, 2021 edited
That's awesome! It's great to see Automation for JIRA receiving new features.
The next feature I would like to see implemented is the following:
Like • Joshua Kochelek likes this
Joshua Kochelek
This is great!! I have so many use cases... Thank you for sharing @Sam Harding!
Céline TAMBURRO May 16, 2022
Hello, is it available on Data Center ? Thanks.
Like • Jamie Gaard likes this
Gisela Lassahn
when will the lookup issue functionality be available for Jira Data Center?
Many thanks (for implementing it and for any answer to my question)!
Gisela
Like • 2 people like this
Stephan Maass March 2, 2023
Is it there for datacenter yet?
Julien Rey
April 12, 2023
@Stephan Maass
The lookup functionality does not exist for Jira Data Center yet.
There is a feature request ticket meant to implement this feature which is tracked in https://jira.atlassian.com/browse/JIRAAUTOSERVER-53
Isaiah John August 14, 2023
Will I me able to use {{lookupissues}} later on in the automation to do actions on the sub-tasks of the lookup issues?
August 14, 2023
Hi @Isaiah John
My guess would be "probably yes" as that data is available for issues normally via the subtasks attribute, such as {{issue.subtasks}}
I recommend testing this by writing to the audit log, perhaps like this example:
{{lookupIssues.first.subtasks.first.assignee.displayName}}
This would log the display name of the assigned user to the first subtask, in the first issue, of the lookup issues result.
Isaiah John August 15, 2023
Hi @Bill Sheboy
Thanks for the reply. How might I go about this?
Kindly provide screenshots of how this could be tested?
It's unclear how to write to the audit log.
Thanks & regards,
Isaiah
Like • Sławomir Kubiak likes this
August 16, 2023
@Isaiah John -- Automation rules have an action to write to the audit log: https://support.atlassian.com/cloud-automation/docs/jira-automation-actions/#Log-action
Please add that action to your rule and paste in the smart value expression I provided.  After your rule runs, you may then review the results in the audit log details to observe what happened: https://support.atlassian.com/cloud-automation/docs/what-are-smart-values/
Alicia April 4, 2024
Is {{issue.dueDate}} support by {{#lookupIssues}} been trying to add that value to an email.  If not is the another lookup that I could use?
Melissa C
Automation has been a life saver!
Lookup Issues Amazing but a let down!!!! Having a trouble passing fields to my email for example {{Issue.Epic Name}} doesn't work
 Any suggestions?
May 10, 2024
Hi @Melissa C
I recommend creating a new question, with images of your complete rule, the audit log details showing the rule execution, of any relevant actions, and explain what is not working as you expect.  That will provide context for the community to offer suggestions.  Thanks!
Chris.Parkes
This is a great feature and I'm hoping something similar is released for Confluence Cloud.
Ben Vere
June 18, 2024 edited
What's the correct form for a custom (dropdown) field using its id? I've only be able to get the value from using its name (c.) as I've only just clocked that you cannot name a custom field "Status" and try to pull its value (As it will pull the ticket Status field not my custom one).
* a. {{customfield_10532.value}}
* b. {{issue.customfield_10532.value}}
* c. {{Result.value}}
June 18, 2024
Hi @Ben Vere -- Welcome to the Atlassian Community!
As this is an older thread, I recommend creating a new question, and perhaps linking back to this one.  That will ensure the maximum number of people see it to offer suggestions.
Until we see that...
I recommend not naming custom fields with the same name as built-in fields; that will both confuse people and Jira processing in some areas.
Next, your version of Jira determines what is available for Lookup Issues.  For Jira Cloud, most of the fields are available Lookup Issues.  For Jira Data Center, only a limited number of fields are available; please look here to learn more about the supported fields and suggestions to add more:
If your field is supported by a Lookup Issues action, and it is a select field, the selections are this:
{{lookupIssues.yourCustomField.value}}
Where the attributes can be found by adding those.  For example, if this is a user select field:
{{lookupIssues.yourCustomField.value.displayName}}
{{lookupIssues.yourCustomField.value.emailAddress}}
{{lookupIssues.yourCustomField.value.accountId}}
If your field is multiple selection, those will produce lists of values.
Finally, smart values are name, spacing, and case-sensitive, and do not always match the display name of a field on the Jira pages.  To identify the smart value, and custom field id, for your field, please try this how-to article: https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
Like • Ben Vere likes this
